Marks Web Site
Date:  8-2-2007
Number of Hours:  10.00
Manual Reference:  8-5, 8-6
Brief Description:  Fuselage center section outer rib fitting
I started by fitting the fuselage center section outer ribs. They had to be fluted into a slight curve. I drilled them to the center section lower skin, F-704 bulkhead, F-705 bulkhead and seat skins. I also match drilled the seat skins to the remaining fuselage center section ribs. Then I riveted in the fuselage center section outer ribs as well as more of the other ribs that I could still reach. Following this I joined and match drilled the fuselage center section with the aft fuselage assembly along the bottom of the F-706 bulkhead.
Fuselage center section and aft  fuselage assembly joining
